"More Boost"
Major Member
- Feb 13, 2005
are all turbo cranks 229 castings? and if so is this the only way to tell a factory (stock) turbo crank? please,
SignUp Now!i was talking to my machinist today and he said all cranks (cast) have fillets but most are "cut" fillets and turbo cranks are "rolled" fillets which is what makes them stronger. how can i tell if they are rolled or cut? (does this make sense?)
two castings.. 877 and 229
Both castings came rolled and non-rolled
HTH
That's true. Also, it's worth noting the rolled fillet cranks are not stronger than the non-rolled counterparts. They can just take more "cycles" at any given power level. FWIW I personally would rather use a nice std/std NA crank from a 60k grandma regal than a 10/10 rolled fillet crank that's been beat on it's whole life.
Also, it's worth noting the rolled fillet cranks are not stronger than the non-rolled counterparts. .
