Have some oil leaks (passenger valve cover) also took off the turbo cover. Looks like I have the bottom line leaking and possibly the top supply line. Two questions.. 1. The bottom drain line. Is that a gasket that can typically be bought at oreillys advanced etc? 2. The supply line the fitting that is in top that screws into the housing. Does this just bolt on or should the threads be taped or anything to help seal? Looks like both are leaking. Any help would be appreciated.
Thanks,
Jeff
Thanks,
Jeff
