Well, Im finally forced to upgrade my turbo.
Over the weekend I had the car out and I made a couple of full throttle hits. Well the last one took out the turbo. I have a stock turbo , was running about 26 psi on alky.....well I got on it and it felt really strong, however when I let off I usually get that silly turbo fart noise, It was only a very silent hiss and then smoke was pooring out the tail pipes..... I limped home and everytime I put any kind of load on the engine it sounded like a really really bad power steering pump noise.
Well I got home and pulled off the inlet hose to the turbo and looked inside and all the fins were really chewed up... HERES THE STRANGE THING... for all the turbo experts....I stuck my finger in the inlet and there was a nut "it was loose" surely that nut does not hold the center section together does it?????
Is this a common problem with stock turbos.....
also I know alot of people say blow off valves are not needed on turbo buicks..... Im not sure if 26 psi is consided high or not on these cars..... but with this kind of boost I wonder if it could have kept my turbo from destroying itself.. I does seem that it was the letting off the took it out.....
Any advise is welcome and what do you all think about a ta49 as a replacement......
this car was a solid high 12 on alky @107
