Turbo(race) motor
seeya v6
For sale 109 long block( just freshned up ) with many upgrades.0 miles!!!
109 block
.040 J+E forged pistons w\file fit plasma moly rings
#2+3 steel main caps
balanced
stock crank cut .010 on rods,.020 on mains w\speed pro "H" bearings
ARP main studs
stock rods w ARP bolts
comp cams roller cam w\lifters 212-212\.504-.504
High vol oil pump
cometic head gaskets
ARP head studs
Ported iron heads w\1.77 stainless intake and 1.5 stainless exhaust valves
LT1 valve springs
solid rocker shafts
stock rockers
oil pan on and engine primed
$3,700 takes it! 0 miles,wraped in plastic.
109 block
balanced
ARP main studs
High vol oil pump
ARP head studs
LT1 valve springs
solid rocker shafts
stock rockers
can i see some pics please!
Phil is the engine builder and the shop is called parts world in Bohemia.Been building turbo Buick motors for 12 years.
where did you get those rocker shafts? I have some that were custom made in TX that look exactly like those.. thinking about mass producing them.
