Turbo Regal Parts from Dynotech - Eric Schertz
dynomarcjack
Still have a large stock of Turbo Buick parts from closing my husband's shop last year (Dynotech of Manville, NJ and Island Park, NY). Listed below is a rough list of parts available.
CASH AND CARRY ONLY. I am located on Long Island. Any interest, please contact Liz....accepting best offers on all!
2 Weld Wheel Dragstar 15 x 4 Rims with Good Year Front Runners
2 Rear 15 x 8 Good Year with MT ET Slicks
New 3 1/2" Houston Style Downpipe with Dumpipe (Dented)
Used Turbo Regal Power Steering Pump
Various Grey Interior Parts
One Black Regal Trunk Lid in Good Condition
Set of brand new Turbo Regal A/C Hoses
Various wheel weld mouldings
2 Used Turbo Regal Fuel Injector Rails
Various Stock Turbo Regal Intercoolers and Shrouds
Stock Throttle Bracket
Aluminum Accessory Bracket
1 Chrome Inlet Pipe
1 2004R Transmission Dipstick with Tube
2 Brand New Turbo Regal 2004R Transmission Mounts
Electric Fan Conversion Kit 85/85-87 ECM Part no. 102030
Unported Used Stock 87/87 Turbo Regal Intake Manifold
Turbo Regal Dash Bezel
1 Used Energy Suspension Urethane Transmission Mount
1 New Walbro 306 Fuel Pump
1 New Auto Meter Fuel Pressure Gauge Part No. 3312
1 New Auto Meter Fuel Pressure Gauge Part No. 4312
I New Auto Meter Electric Trans Temp Guage Party Nol. 2640
1 New Mechanical Oil Pressure Gauge Part No. 3421
1 Set of New Comp Cams Beehive Springs Part No. 26918-12
2 New TCC Torque Converter Micro Controller (L/U)
1 New Stock Oil Filler Tube with Cap
1 New Holley Kickdown Lever 700R4 Par t No. 20-95
1 Set of Turbo Regal Engine Fuel Lines
6 New MAF Brackets
1 Used Grey TType Horn Pad
1 New Set ARP Turbo Buick Rod Bolts Part No. 123-6002
2 New Express Power Window Module
1 Caspers Positive Battery Cable for 86/87 Turbo Regal Part no. 102024
1 Set of used 1/4" wheel spacers
1 New GM Grey Shifter Handle Part No. 22525558
1 New KD Piston Ring Filer
1 New Pro-Gram Engineering Front Billet Main Cap
1 New Pro-Gram Engineering Rear Billet Main Cap
2 Stock Turbo Inlet Bell
2 Various Turbo Inlet Bells
1 Stock Up Pipe
2 New K/N Clamp On Breathers
1 Used Turbo Regal High Pressure A/C Line
1 New GM Head Gasket Kit Part No. 89017824
1 Caspers Performer Chip 93 Octane 30lb. Injectors
1 Caspers V+ Volt Booster Part No. 102027
Magnecor Ignition Wires for 85/86 2 for GN Regal and Riviera Turbo 84/85 (Part No. 6031)
Magnecor Ignition Wires for GNX 86/87 and 1989 Pontiac Trans Am Turbo (6554) New
Magnecor Ignition Wires for Turbo Regal - Part No. 6054 and Part No. 6555 New
Magnecor Ignition Wires for Turbo Regal 84/85 Grand National Riviera Part No. 6531 New
Magnecor Ignition Wires for Buick Roadmaster LT1 - Part no. 80205 New
One Stock Turbo Regal Gauge Cluster (Used)
2 Regal Rear Transmission Mounts Part No. 2379
1 Pair of Stock G Body Upper Control Arms with Urethane Bushings
1 Pair of New G Body Just Suspension Upper Control Arms
1 Set of Hochkiss Upper Control Arms 94-96 Impala SS Non Adjustable
4 Number 33-2141 -1 K/N High Flow Air Filters - New
1 RU 2510 K/C High Flow Air Filter - New
1 RE 0810 K/N High Flow Air Filter - New
2 REO920 K/N High Flow Air Filter - New
4L6DE Swiss Cheese Drum
1 Used External Waste Gate
New Turbonetics Waste Gate
Adjustable MSD Ignition Adjustable Timing Control for 81-86 GM
TY 140 Battery Relocation Kit
2 New Variable Waste Kits Turbonetics Manual Boost Controller Kit
1 Used Chrome Master Cylinder Cover
1 LS1 Valve Cover Breather
Denso Oxygen Sensors 234-4012
(2) Denso Oxygen Sensors 234-4087
4 Sets of (4) XP103 Xtreme Performance Iridium Spark Plugs
3 Sets of (4) XP103 Xtreme Performance Iridium Spark Plugs
1 New Set of (6) 75 Lb. Delphi Fuel Injectors
2 Used Turbo Regal Stock Air Filter Assemblies
3 Stock Turbo Regal Dog Houses (Upper Plenum)
1 Mease ported throttle body 65 mm
3 Stock Turbo Regal Throttle Bodies
1 Polished Upper Plenum with stock throttle body (Turbo Regal)
DIS MSD Interface for Turbo Regal
Used ECM's good for cores
1 Stock mass air sensor for Turbo Regal
TCC Torque Converter Controller for Turbo Regal
1 Cloise Turbo Regal Chain Set Part No. C-3018K
New MSD Adjustable Timing Controller Part No. 8680
New Standard EGR Valve
Used Buick Motor Sports Aluminum Valve Cover
New Racetronix W Body Plug & Play Fuel Pump Hot Wire Kit
1 New Casper Field Fix Alternator Harness fits 1986-89
New Belt Tensioners Good Year Surp Belt Tensioner Pulleys Part Nos 49011 and 49003
New Precision Turbo Fuel Pump Part No. PFU 045-3030
1 New Power Steering Cap
2 Walbro Fuel Pump Part Nos. GSS-341 and GSS-342
Front Wheel Drive Chain and Gear Set 3/8 Drive Chain Set 2.93 GM Gear and Chain
Used Stock GN Radiator
Blower Pulleys for Front Wheel Drives (Wbody)
1 Caspers Valve Cover Filler Tube with Cap LS1/3800
New Precision 67/85 Exhaust Housing 4 Bolt Turbo
New Lower Trailing Arms Hochkiss Performance for Impala SS
1 K/N Push on breather part 62-1470 new in box
4 Turbo Regal Stock Balancers
4 Stock Turbo Regal Pulleys
New Comp Cam 3800 V6 Chevrolet Hydraulic Roller Tappet Xtreme Energy Camshaft?
Used gas tank straps for Buick Regal
Various Grey interior Parts for TTYPE..Seats, Door Panels
5 used Turbo Regal Steering Wheels
Set of Rear Side Glass for TTYPE
Manifold Cover 3800 Supercharged
Stock GN Manifold Ported (1200 Gasket Only)
Karp Trans Blanket
Assorted Fuel Rails and Wire Harnesses for Buick Regal
2 Lock Up Solenoids 4l60E/700/2004R
2 Sets of Stock Valve Covers
Used windshield washer tank
3 ALTO Clutch kits for Direct Clutch High Performance E40D and C6 (New in box)
2 Used Intercooler Fans
2 New Stage II Cam Shaft
1 Set of intercooler brackets
New Dynomax Super Turbo Aluminum Muffler
75lb Delphi Fuel Injectors (6 )
Negative Battery Cable
Stock Fuel Return Line
1998-2002 Dodge Durango Front Brake Rotors
Stock Buick V6 Water Pump Kit and Stock Crank Pulley (New)
Gauge Pillars
2 New High Performance B&M Supercool T ranmission Coolers
Radiator Hoses for Regal - Dayco Coolant Hose Part No. 71755
New Borg Warner Cam Shaft Sensor for Regal Part No. 25516915
Late GM ARP Wheel Studs - Part No. 100-7713 and 100-7708 (New)
Caspers 86-87 Turbo Regal Ultrachip Standard Version 3 for 55lb injectors
Felpro Exhaust Header Gaskets - 79-87 Buick V6 - 10 New NAPA Ones
Upper Plenum Gasket for Turbo Regal
Primary and Secondary Piston Assemblies
AC Delco Power Master Kits
Various Buick Emblems
Competion Engineering Fuel Tank Sump
Turbo Boost Line part and Tees
Exhaust Clamps
Assorted Chrome Engine Pieces for Turbo Regal
Assorted Front Wheel Drive Blower Pulleys
97-2003 Gran Prix Gt/GTP and Regal GS Fuel Pump Wiring Upgrade Kit
Garrett T3 M10 Turbo for Ttype and GNX
1 Wire Oxygen Sensor for Turbo Regal
Easy Performance IAT Selector Switch
2 IAT Sensors
Easy Performance w BODY Fuel Pump Rewire Kit
4 Rear O2 Sensor Simulators for Turbo Regal
Caspers Electronics Performer Prom Chip Turbo Buick 3.8 1987 Octane 93 42.5 Injectors
Walbro Fuel Pump Kit No. 400-812 (New)
Clevite Cylinder Head Bolt Sets for 3.8 Motor
Felpro Head Bolt Set for a 3.8 Vin B 86-88
HKS Type O Turbo Timer Part No. 4200171
84-87 Turbo Regal Upper Body Bushings - New Pair
Casper Electronics 86-89 Delay Relay
Casper Electronics 86-89 Alternator Harness
Casper Electronics 86-89 Oxygen Sensor Kit
Intense Racing Generation 2 1/2 Slip Differential
I WIN Engineering 3800 Rocker Arms
2 Transmission Coolers Import and Small Truck
VDO Water Temperature Gauge
Melling Screen Engine Oil Pump Pick UP
MSD Ignition Soft Touch Rev Control Mag & Points Part No. 8728
Jacobs Electronics Boost-Master Part No. 382606
4T65E Differential New In Box
New C6 Ford Forward Clutch Drum
Comp Cams Part No. 76-000-9 1 X Blower Cam
Various Computer Chips for Turbo Regal (Kenne Bell 36 Lb, 42, 50, 55 Lbs)
(6) New 32 lb. Disc High Fuel Injectors (Green Stripe)
Please PM me with prices on the following parts.
Thank you.
Bryan
(are these black?)
(is this a complete handle with button and spring? )
Gauge Pillars
(full pillar? looking for a dual or a triple in grey)
(need full set of 87 GN emblems-new)
2 Used Turbo Regal Fuel Injector Rails --STOCK?
1 Set of Turbo Regal Engine Fuel Lines --STOCK?
TY 140 Battery Relocation Kit -- ALL THE WIRING?
Used Buick Motor Sports Aluminum Valve Cover --JUST 1?
Various Grey interior Parts for TTYPE..Seats -- FRONT AND REAR?
Gauge Pillars --SINGLE, DOUBLE OR TRIPLE?
Various Buick Emblems -- 3.8 HOOD (2X), INTERCOOLED(2X), 3.8 REAR, BUICK?
Hey Ms. Liz, got a few items that I'm interested in. Thx......:biggrin:
Wow big list.....to fetch best dollar I'd list items on ebay. Posting a list that big is going to create a lot of work for youself dealing w/ pm's, emails, phone calls and lets not forget low balling. If it were a smaller list, it would not be so bad in this style of listing. Auction style is always less hassle and will bring you best dollar....just a thought.
Best of luck to you......:)
I hear you loud and clear...especially since I am depending on my husband's Buick friends for help on sorting all this stuff out. I have had this stuff since I closed his shop last year after his passing so I was really trying to just sell some of it to nearby people and whatever doesn't sell...it's going to someone to sell on ebay for me...don't have the time to do shipping, etc...we'll see how it goes...Thanks. liz
X2 On that one.That is going to be alot of work.Maybe one of the other venders would buy as a lot. good luck
This stuff will all go quick if you decide to ship. I understand though trying to sell local. Wish you were closer, id make an offer on the whole lot. Maybe someone local with a little bit of extra time can buy the whole lot and be able to ship the stuff out. Anyways good luck, you have alot of needed parts.
pics of external gates
beehive springs
felpro 1200's
upper plenum gasket
caspers battery cable+
shipping to 91606????
and price
turboelky@gmail.com
thanks!!
pm me if you decide to send pics/ship these parts. If everybody buys several parts, you'll only be shipping a few boxes. At least it would sell! I doubt there is enough people local to you that needs all that stuff. Thanks!
will do. would love to get rid of all it now rather than giving it someone to ebay for me. It really comes down to if someone wants to purchase enough items, it might be worth my while to ship..just didn't want to ship every little item out..just don't have that kind of time.
Liz
Liz,
I know it says cash and carry but,would you ship to CA.the pro-gram
engineering billet front & rear main caps for the right price?$280?Let me know.
John
Hi, I would like the 86-87 intake,if you would ship, it would be a long drive from Idaho, though I would not mind doing it if I did not have to work, that darn work seems to always be in the way of doing things, thanks.
Ron
and what kind of wastegates are they??
I'll give you $100 plus shipping on above post, plus depending on the gates brand and size, more money plus more shipping. We will all make it worth your while.
Hi Liz, how much are looking to get for the from 15x4 and 15x8 weld prostar wheels with et radials? Also what is the condition of the wheels? Thanks......
I am interested in the Auto Meter Electric Trans Temp Guage Party Nol. 2640.
Is $30.00 plus shipping a reasonable offer?
Thanks,
DGC
Buick Parts
Just a quick apology to everyone for not being able to get back to anyone...had a power outage where I live for most of the day until tonight..will do my best to reply to everyone by end of week! Hope you're all keeping cool in this awful heat! Liz
