Turbo saver placement issue. Need help
larry33kc
Have a turbo saver with the very large filter as most of you do. I know most mount it in the grill area or behind the headlight area.
My problem is that both of those areas are taken. I have my Alky pump in the grill area , and an trans cooler and fan set up behind the headlight wheelwell area. So what are some of my options. Please help I want to run my TS.
I have mine mounted on the inner fender below and forward of the batt.
I asked because I don't see how it would fit I have oil lines running there
I have mine behind the headlight and my alky pump in the same general area (bolted to the bumper bracket studs) and my cooler is behind the grill. If you have a fan in the transcooler it opens you up to putting it more places.
I'm running all braided oil lines so I have more flexability. I also have a fan cooled trans. cooler which is being moved to the area below the head-lite/batt. area instead of in front of my fmic.
Yes, you might be able to take a pc of alum. angle or channel and make a bracket to attach to the frame, allowing the oil lines to pass behind it.
