Turbo Selection & Stall
bluezone
My Stroker Build is almost complete... I need some help with a turbo selection as well as converter.... Here is a list of my build.... I love for this build to be a nasty street/strip combo
109 Stroker Bored 30 over...
DLS 218/218 billet roller cam kit
3.5 V Band down pipe
Billet Mains
Champion 14 bolt Aluminum heads with race port
Champion intake
GN1 72mm throttle body
Fast System
Alky system
Transmission 200r4 built by Four C's
My wife had a 6265 and a 3200 with old combo close to yours worked great, now a 6766 have not started new engine up yet
K... Keep me posted... I was thinking of a precision or Turbonetics 70 series billet ball bearing turbo jus was wondering will it have turbo lag or a good spool up
For a street car, static c/r makes a big difference in spool time. Most of the newer builds are w/9:1+ and you may get good response w/a 70 series. I would recommend the precision dbb. I had the 71 gtq and it was lagging. I'm going w/the t-netics 76 now, but I have low static c/r and the 76 will puff to 45 psi. It gives me room to experiment, it's an sg-1 block! Pat or Bison would probably be the best ones to offer a suggestion as they have more experience w/the turbo choices. Then Dusty can best spec the converter for your choice.
That would depend on the power needed. The engine will peak around 5500. 6265 will make 9 sec power. Any HPQ/GTQ will have some lag. The 65/66 ex wheels will work well and spool a lot faster
