Get a mm ruler or tape measure and measure your blades flat edge to flat edge on the inlet side. It will be close. Pics can be deceiving , to me it looks like a 64 or 66mm. It wiill take someone with massive skills to tell you what the trim is if you need that info. What waste gate do you have for it? I see the manual boost controller for it. Also post what size the A/R is on the compressor and turbine housing. Then the same people with the massive skills will tell you your approx. hp range. Just kidding, it late.....err early.
