SignUp Now!Wear, dirt, oil pressure too high with the wrong viscosity, a bad rebuild or just a bad build on a turbocharger.
The most oil consumption I've ever seen with these turbo's is the turbine sealing ring will wear the center housing out in it's bore.
Kinda on the topic, my turbo needs a new carbon seal probably. My engine had 3 spun rod berrings and a bunch of trash in the pan so im going to guarentee somthing got in the turbo. Turbo was tight and spun good though.
What all should be done on a turbo rebuild. Theres a turbo rebuilder about a hour away from me that works with mostly truck and tractor turbos. I know for sure new seals and berrings and to get the wheels balanced but is there anything else?
I get white smoke all the time and my oil burns at like a quart every 200 miles. The rings have had to seal and the heads seal good. Only other option is the turbo, I hope....
Sounds like the carbon seal is out Jim. Standard rebuild should take car of it.
Carbon seal on the compressor side,maybe.I was figuring on the exhaust side there was an oil leak since it is white smoke not blue.Blue smoke means oil gets burned in the combustion chamber,white it is heated up not burned.
are you sure about that Jim?
if its blowing out the turbine side it will be blue as well.... the turbine is a hot bastard. i would pull the downpipe and confirm oil residue on the turbine.
white would be steam.....
A.j.
If that's your car then it's oil, no questions asked. It's not white enough to be water. You need to go ahead and rebuild the tubo Jim.
Well get to swapping Jim. Happy new year. There a newby in your city that could use your help if you feel like it. He's got an NA 85 and has no clue on how to work on it. He posted in the general section I think.
http://www.turbobuick.com/forums/be...d-some-project-encouragement-just-update.html
Take a look and see if you can help him. I'm a little to far away so it's kinda hard to do it for me. Thanks.
