Turbo specs
badtbuick
I currently have a te64-1 turbo and was ether going to rebuild it or get a new turbo, does anyone know to what new turbo model #does this compare to?
The MFS 6265 is a close comparison
Thanks bison for the info do you know if there is a spec sheet for the te64-1 I lost my sheet , out of the game so long I can't remember what the specs are
The name is a made up name it doesn't correlate to any Garrett product. Should be the 66mm inducer tv45 compressor and a clipped P trim t04 76 turbine large shaft. With a good set of heads it will move a lot of air in a v6 with boost in the mid to high 20's.
