I think I got mine from there as well.  only issue I noticed regarding an externally gated dp is that the gasket is only the outer oval and doesn't seal the waste port from the main exhaust outlet...meaning it would allow some exhaust to escape the waste port into the main exhaust run causing boost to be slightly lower than it could be.  for an internal flapper type it should work fine though. unfortunately for me I am unable to use them.
