Installed my TT 6.1 & 80lb hour high-Z injectors along w/the Power Logger. Car started right up, idle was rough but the fuel system was also bone dry to swap tank from 93 for E85. It smoothed out and idle was pretty good.!
Let it warm up a few times, seemed pretty solid with a slightly rough idle at start up.
Tested PowerLogger, connected and could see my AEM wideband, data in Powerlogger matched what the gauge displayed. 10:1 was the average idle A/F.
Set fuel pressure at 43, reset the chip, started up and let idle until 180 degrees or so. Turned off the car and then restarted it so I could give it 15 minutes of city driving on E85 so the chip could learn.
Went for a test drive, drove fine down the street. Took a right on a larger street and applied more power and I heard a "pop" and it sounded just like a pipe blew off and the car acted just like it was having a tough time understanding the amount of air going into the motor.
Limped it home, pulled back in the garage, all the pipes were on all the way, nothing was loose! Checked the PowerLogger gauges and the only thing that is weird is the MAP is seeing -29.5 hG at ALL times it never moves. With the car running I unplugged the sensor no change. I reset the MAP absolute zero using the CTRL-B command and it set to 0psi. Restarted & the sensor doesn't move plugged in or not. Not sure what the MAP does for the factory computer because the more I read on the PCM layout, it doesn't seem to pay attention to the MAP but that doesn't make sense to me but I'm used to LSX based computers....
I researched what could be causing this last night and I've come up with a few ideas for trouble shooting:
Step 1) Grab a new MAP from AutoZone and test
no resolution
Step 2) Remove PowerLogger and drive the car with just the 6.1 Chip (if this is possible not sure)
no resolution
Step 3) Burn car to the ground
No just kidding but I'm not sure what else to do if those steps don't work....
Please advise
no resolution
no resolution
Please advise
