1984 t-type
Murphy's Law
- Jul 11, 2010
Just wondering if anyone was using this yet or heard any feedback on it. I'm curious how it compares to the translator.
SignUp Now!Eric, does the AXiS chip have features like fast update patch, antistall, false knock ignore, etc. built in?It's brand new, so only a couple out there.
This is for the guys that want to keep tuning simple. No menu's or laptops, just little dials in the box. You can adjust fuel and spark at the low end and WOT. Spark control is done through the airtemp input (you will no longer read airtemp).
It can work as a basic Translator with any chip (spark control and WOT fuel won't work though). The AXiS Interface is basically one step up from a basic Translator.
I have made a special chip for it, the AXiS chip, which enables all the features of the AXiS box. In keeping with the "keep it simple" approach, the chip has NO user adjustable parameters, no worry about disconnecting the battery. The AXiS chip will read to 512 gr/sec, which is good for about mid 10's. You only need one chip for street or race, as you can just dial the spark advance up or down in the box.
The AXiS chip is currently only made for 60lb and 80lb injectors. I will do a couple more calibrations over the summer, probably for 42's and not sure what else yet.
If you still want some adjustable features in the chip, you can get an Extender Extreme chip, but it needs to be special ordered for the AXiS. It will read to 768gr/sec.
Here's a link to the instructions if you want to check it out: http://www.turbotweak.com/axis_interface.pdf
Here a link to it in my webstore: http://www.turbotweakstore.com/SearchResults.asp?Cat=3
Understood. Appreciate the response.The Axis chip is basically my 5.7 chip without any adjustable features, but I added the 512gr/sec capability, and the timing control.
So it has all those features you mentioned still built in. Fast update would have to be requested.
You pretty much got it covered. I've been running the AXiS Translator and chip for about 8 months now. My only concern at first was that I'd lose the ability to adjust 1st gear WOT fuel and timing in low gear. As it turns out I don't miss it as much as I thought I would. Keep in mind I don't race my car but someone who does might want the added adjustability. In the end, I'm happy with the unit and would recommend one for anyone who does not need/want the full menu of adjustability a TT chip has to offer. The AXiS controller is also slimmer which may provide more mounting options and just looks better to me.Hi guys, I wanted to revisit this topic...last summer when Eric last commented here, I was researching all the things I needed/wanted for an intake I'm building myself. I'll be running a 3.5" LS1 MAF and running a 3.5" intake pipe up to the turbo inlet (most intakes I've seen are 3" up to the turbo). This summer I have the budget for a chip and MAF translator to complete this mod. If I understood all that I read about this, here are the pros & cons; please correct or confirm if I have anything wrong. I am currently running stock injectors but will upgrade to 60# injectors at some point in the future. I'm running 91/92 octane premium pump gas.
Axis translator & Axis chip combo:
Pros: The most plug & play system ("KISS"); should work with stock injectors; won't lose tune info if battery disconnected; combo is cheaper than buying MAF translator + TT chip separately.
Cons: Limited adjustability.
MAF translator & TT chip v5.7:
Pros: More adjustability.
Cons: Costs more; tune info lost if battery disconnected (without buying the $50 Tune Saver).
So given that info, is there anybody here who has used the Axis box & chip combo with a GN running stock injectors who can provide some input on how it works? It seems like the best option to go with even if sacrificing some adjustability. Is there any reason *not* to buy the Axis combo?
Thanks for the help.
