turbo upgrade?
turbo tom
Whats the biggest turbo that you can put on a mostly stock GN that has good street manners?
What stall and what other if any upgrades?
I believe the stall is 3200 and the injectors are green stripe 10% higher that stock.
With the right convertor, PT6776. Thats what I have on mine. Stock long block with bolt ons. I have a Pats 10" 3400 stall, and great street manners
I wouldn't try over a 49 with those injectors... With your stall you could use more turbo, but that would require an injector change... You also need to make sure you have a hot wired F/P and adj regulator to start off with too...
THANKS FOR THE INFO, ILL PROBABLY GO TO THE 60LBS INJECTERS AND A BIGGER TURBO SOMETIME AFTER cHRISTMAS.
I have a 3" downpipe from SE Turbo on my car. There are many different 3" downpipes for sale from different vendors
When Im done and everything is fine tuned I plan to be 11.00's to high 10's
