Jon Early
- Dec 4, 2014
Long time no post! I wish I had better news, but the car has been tucked away almost since the last time I posted.
Stock T5 + 400lb/ft to the tires = Chunky metal soup! See! Even the RWD 3800 guys were stuck with bad transmissions. I plan to upgrade though. The T5 is not a transmission worth building up if you ask me. With every action comes an opposite reaction, so when you start applying a lot of torque to these transmissions, the gears naturally want to spread apart from each other instead of spinning. Since third gear is the center most gear on the main and counter shafts, it always suffers the most. Eventually it spreads the shafts so far apart that the gears are only contacting at the tips of the teeth which causes them to chip and break off. There are upgrade kits available with stronger shafts, and gears with less of a helix in them, but buy the time the rebuild is complete, you've spent about as much as it would cost to buy a brand new trans mission with a much stronger torque rating.
There is very little information when it comes to this kind of conversion on the 3800, but I'm going to attempt to document my journey in the best way possible. I have a couple more measurements to take before I pull the trigger on a $2600 transmission, but I'm already pretty certain that this car will have a GM style TKO 600 in it pretty soon!
Despite the 4th generation F-bodies using a Ford T5 case, I plan to use the GM style trans. There are several reasons for this. First of all, the Ford TKO uses the "wide" pattern while the T5 uses the "narrow" pattern. This means that none of my bells will work without an adapter plate. The Ford Input shaft is slightly longer which is why I leaned that way for a little while, but the width of the MDL narrow to wide pattern adapter would make this a wash. The final nail in the coffin was that the GM pilot shaft would allow me to modify an off-the-shelf SBC extended pilot bearing instead of needing to make a bushing from scratch. The only trick left is finding a bell that has the metric engine bolt pattern, a non-tilted Muncie pattern, AND a driver side starter pocket...
TA-DA! Enter the V6 3rd-gen F-body Bell. It's not perfect, but its pretty dang close.
View attachment
As you can see, GM made this bell for a tilted set-up, but also cast in provisions for a vertical orientation. I have no idea why, but I'm really glad they did! I have to make some calls, but I do not believe that a TKO is supposed to be tilted. I'll just have to finish drilling and tapping the holes that GM already started. They also cast the fork provision in such a way that cutting it off and making a nice little window for HTOB hoses to come out will be super easy. Even if TKOs could be tilted to the driver side like stock, mounting it that way and coming up with a shifter could be a big pain. Mounting it vertically should just mean that I will need an offset shifter and stock mount which are widely available.
Wish me luck! I'm sure to run into some problems. So far, so good though! I'm getting so good at pulling this T5 that I actually remembered to pull the drain plug BEFORE I pulled the yolk!
I might actually stay sort of clean.
View attachment
View attachment
View attachment
