I haven't been here in here much, but I've still been slowly plugging away. Life has been getting in the way, and the Camaro is at the bottom of the list of priority. Since this car is so incredibly rusty I decided to turn my 20 minute rear sway bar end link job into a couple days. There are pedestals that bolt to the frame in order for the links to have something to mount to. They collect water and mud like crazy, so naturally they were in very poor shape. I cleaned them up as best as I could with the wire wheel, welded reinforcement washers to the bottom, repainted with rust inhibitor, and now they should be stronger than they ever were. The car handles a lot better too!
After more hard thinking, I figured out that narrow band problem as well. I knew that the car couldn't be running as well as it was without any signal voltage from the O2 sensor, so I turned to the Aeroforce user manual. Apparently some things can't be taken too literally. GM likes to name their sensors funny, so "Sensor 1 Bank 2" is actually the post-cat sensor which I deleted. "Sensor 1 Bank 3" is actually my Bank 2 sensor.... Thanks for that confusion, GM.
Anyway, the car runs flawlessly, and I'm super happy with it. I recently sold my deadbeat '88 Chevy C1500, so hopefully I'll have more time to work on the Camaro as I shop for a nice new truck. Next on the list include:
-Block PCV so that I stop boosting the crankcase!!
-Catch can
-Rear main seal, pilot bushing, clutch hydraulics
-Replace the rest of the brake lines
-Finish and install coolant reservoir
-Battery cut off switch?
Maybe then I'll be able to get a dyno tune and some track time without making a mess.
