turbo
scottk
what turbo should i buyGT6776bb or CPT66BB? the precision is more $$$$$$ the car is mostly street driven!Ihave a 3200converter!:confused:
scott,
Do you realize that you'll have to upgrade chips and injectors to 55-60's? What are your goals, and how loose is your converter really. You will loose a some spool up going much bigger on turbo. If your car doesn't spool "instantly" now, the you'll have to deal with some slow slow spooling some how. My guess is that the precision is slightly better, but both will get the job done. We're all biased on turbos here. So expect most people to say precision.
How fast are you really wanting to go? We all have turbo evy and want to run a 70mm if we could. If you're just wanting to go high 10's, then get a pt52-54. They'll make more power then the TE44 and still spool good with your converter.. and be cheaper. or heck.. the TE44 can do it with the right combo and lots of boost.
anyway.. that's just my .02
A 66-7 BB should spool just fine with a 3200 stall I would think...50's would also be fine for now as long as he's careful with boost and doesn't let it go lean.
I have all the supporting mods on my new motor:smile: just wondered about the bbturbos
