I just installed a new downpipe with an external wastegate and a Turbonetics boost controller (nothing fancy; basically just a 0-50 psi air pressure regulator). In the instruction sheet that came with the controller it says to go downstream of the throttle assembly for the boost connection, which to me would mean tapping into one of the lines coming from the vacuum block since this would be behind the throttle blade. However, I've seen pictures where it looked like people have just used the barbed fitting on the compressor housing as their boost source--if this is OK I'd rather do it that way since the fitting is there not being used for anything else...I was just wondering what other people's thoughts on this were? Is there any reason I shouldn't run it straight from the compressor housing?
