just installed a turbonetics boost control this thing sucks verry hard to control boost jumps to over 20psi when closed anyone know of a good manual cockpit boost controller
I havn't installed my manual boost controller yet, but i heard I should watch out, because the longer the boost line(from turbo to inside ur car) the harder it is to controller exactly how you want it. I dunno tho, just my 2 cents.
What type of a wastegate are you using? The manual boost valves are designed to work with external wastegates. They work very well, also they come in several different boost levels, if you have the wrong one for the application, it will not work properly.What number do you have?
