I don't have any used turbos. Availability and prices subject to change at any time. Any reasonable combo of wheels can be had if available. Ball bearing not listed available at times. Cartridges available. Parts, balancing, and custom machining available. For higher hp applications message me specifics about the application. Stock appearing turbos readily available for most of the 58 through 62 inducer turbos but have $125 housing core fee. Stock appearing 64 available but need lead time. Some turbos listed are updated units and some are 100%new. I dont sell used turbos unless noted. All new/updated are 360 degree thrust and staggered gap ex sealing ring unless noted.
Stock or stock appearing:
TA49 $695 exchange
TA60 $695 exchange
TA61 $695 excahnge
TA62 $695 exchange
TA5857 MFS $875 exchange
TA5957 MFS $875 exchange
TA6265 MFS $875 exchange
TA6466 MFS $975 exchange
TA6266 MFS $975 exchange
stock 86-87 TB0348 with dynamic thrust assembly for lower drag/faster spoolup $425/$125 core charge. Cartridge only $395 outright.
stock TB0330 $450/$125 core charge. Cartridge is $450 outright. Add $40 for 360 degree thrust with carbon seal
stage 2 Garrett .82 a/r ex $425 exchange
Large shaft stock appearing turbos ( 63, 64, 66, etc) available but are much more expensive.
Inlet bells extra
T04E compressor cover below unless noted. Add $35 for 4" inlet 2.5" outlet
TE44 $695 new polished cover
TE60 $695 new polished cover
TE61 $695 new polished cover
MFS 5957 ball bearing $1495. 4" inlet cover add $35. Will spool with 12" converter with Garrett .63 housing. Water lines not included.
6131 ball bearing, $1295, $1425 with Garrett .63 (GT35r compressor) Water lines not included
TE62 $695 new polished cover
60-1 S cover small shaft P trim $545 Garrett .63 $595 Compressor cover is chrome plated
MFS 5957 new polished cover $875. 4" inlet cover add $35
MFS 5965 new polished cover $875. 4" inlet cover add $35
6152 S ported cover $695
MFS 6265 $875 new polished cover. 4" inlet cover add $35
MFS 6266 $975 new polished cover. 4" inlet cover add $35
MFS 6466 $975 new polished cover. 4" inlet cover add $35
6376 (TA45) T04S04 cover $745, $795 with Garrett .63
MFS 6765 $975 new polished cover 4" inlet cover add $35
MFS 6766 $1075 new polished cover 4" inlet cover add $35
6776S $749 Precision .63, Garrett .63 $795
MFS 6766
MFS 6265
6776 (T04Z/T04 76 trim)
6152 (GT35R/stage 5)
TE44 (T04E60/stage 3)
TA49 (T04E60/stage 3)
CEA 6265
BPE2013@hotmail.com
TA49 $695 exchange
TA60 $695 exchange
TA61 $695 excahnge
TA62 $695 exchange
Inlet bells extra
MFS 6766
	MFS 6265
	CEA 6265
	BPE2013@hotmail.com
