Turbos for sale TE, TA, MFS Stock to 900hp
Both are good street strip turbos. 10 sec potential and the 6776 has been 9's years ago. Both need a good converter if pushed hard
I see you have a new variant, if you will, of the 6265 - CEA 6265 $895 (new take out turbine). I'll look up CEA, but what does take out turbine mean?
It's not a variant. It is a cea 6265. Precision wheels. It was the 65 wheel that Precision used right before they switched to the 66. The 65 wheel will flow the full 100% potential of the 62 compressor wheel with no problem.. Take out means I took it out of another new unit. I believe it was a 6765 with a large compressor cover. The reason I would do this is because I know the potential of the 67 compressor wheel and the 65 turbine would likely choke flow before the compressor was done. Re-balance the 65 turbine with a 62 CEA I had on the shelf and balance the 67 with a new 66 turbine and now there's two turbos with well matched wheel combos.
Thank you for the explanation. I'll send you a PM, with other questions.
TTT
Bison--can I call you tomorrow to discuss my turbo failure and what replacement turbo should I use for my car? Thanks.
Yes call or text me tomorrow after 12est
TTT
Bison, as soon as my engine builder gets back from vacation I will contact you and we can discuss the turbo. Also want to discuss a custom CAM grind.
Let me know when you're ready.
Replied to PM
