That makes sense but I really don't want to splice into the factory wires. I'll check with the local parts stores and see if anybody knows of a loud flasher. Even if it doesn't plug directly in, I can always make a little jumper harness.No. It would beep with the turn signal lights. You would have to wire it on the lights side of the flasher module. Just use one of those snap-lock type crimps on the positive side of the buzzer and then connect the ground side to any good spot near buy. Done.
