Originally posted by salvageV6
Come on Dave you got the manual open it.
I obviously have never had that weird problem so I have no clue.
Manual wasn't all that clear where the splice was but looking at the fuse distribution page for that fuse I would say at the gear selector switch.
That should be located attached to the base of the steering column according to the manual. 201-13-A is the page for the picture, sticks out the top of the column of course where it's hard to work on.
Look for two dark blue wires, one crushed.
Now how do I fix my code 42 problem in the rain? Oh wait I know wait for tomorrow.
Car still runs too, prolly the translator timing circuit or the new extender chip, or some rain water.
Salvage, THANKS for steering me in the right direction. I was so ticked off at the car I hadn't touched it in a couple weeks. Today I went back out and crawled under the dash, laying on my back, (on the seat because of the roll bar mount being in the way on the floor). My back will never be the same.
Anyway, I was looking around up there by the gear selector switch, and saw the open connectors where something used to be plugged in. Then right there in my face was hanging that connector. It had two dk blu wires into one side and a lt grn wire out the other.
OMG! I had forgotten that way back about 15 years ago when I installed the B&M shifter, I had gone under there and disconnected that switch and cut the lt grn wire to the backup lights (because this was years ago when I didn't know how to hook the shift column lever up to the tranny with the aftermarket lever in place).
Anyway, I had used one of those pinch splicers on one of the dk blu wires to supply 12v to the shifter's back up light micro switch.
My suspisions are that that connection probably has become corroded over the last 15 years somehow, and when loading the circuit, it somehow broke the circuit. After wiggling the connections and playing with it, the turn signals now work
I suspect that pinch connector must be on the dk blu wire going to the turn signals because the backups worked just fine.
So thanks again salvage!! this was truely a ball buster.
