tv checkball???????????????????
Slick87gn
still finishing up the install on the BM shift kit. I did not see or can find the TV checkball. I have the bracket spring and what appears to be hinge pin but no checkball.:confused:
I removed the TV exhaust check ball per the art carr high valve body kit. if that is teh one u are reffering to then all is should be fine
You don't need it. Just remove the spring and lift pin. It's there in case the T.V. cable breaks or becomes disconnected.
