http://www.espperformance.com/twins.html
I was reading on this websight the other day and it mentioned this twin turbo setup for the Grand National engine. It claims to generate 500hp while maintaining lower temperature and 10lbs of boost pressure in the cylinder walls. I'm no turbo expert but I would think that 10lbs of boost from one turbo or two wouldn't make any difference to your engine. Wouldn't one turbo at 20lbs of boost be the same as two turbos at 10lbs of boost each...or does air work differently when calculating that? I know the twins would spool up faster but would their actually be such a drop in total boost pressure and still maintain the horsepower?...or are they refering to each turbo running at 10lbs? I'm not trying to make any accusations against the company I'm just trying to gain some understanding. Thanks for any help in clearing up this confusion for me :biggrin:
