Boostian
- Jul 8, 2013
Ok, my kit had been installed for about a month now and running flawlessly. Smooth, tuned decent, and safe. Here's my issues:
On two occasions I have come out to my car to find the tank empty. The first time was at a weekend car show and I figured I had just used all the alky. Filled it up for the ride home and got on it maybe three times for short 4 or 5 second bursts on the way home, then parked it. Came out Friday (three weeks later, car was parked) and turn the car on, low fuel light. Check, tank is empty. Wtf. Fill it half way, check for leaks, see nothing again. Could the leak be sooooo slow I'm not seeing it?
Second issue: Friday after I put a half tank in the alky tank and start driving I hit the test button as usual. Red light comes on, engine stumbles after about 4 seconds, no green light. Try again, held a little longer through stumble, no green. Worked before? As I'm just bringing it into boost the low fuel light flickers a bit periodically. What gives? Tried cautiously to slowly bring it into boost once and light turned red at around 7psi and green it seemed around 12.
Am i having issues here? What's going on?
