UCA bushing removal.
jpratt
How do I remove the upper control arm bushing on the the top of the diff? I have beat, pryed and yelled at them but they will not budge.
HRParts makes a neat removal tool for those bushings. They are a vendor on this site.
It might take you 3 mins tops for each bushing with the tool. You've already tried the other ways. It can be done without the tool, but it's a PITA.
Hope this helps
Billy
Montgomery Village, MD
lock the arms in a vise and get out the air chisel.one more thing,take your time:D
On the car?
Never tried this with the rear still in the car---If you can get to the bushing with a drill---drill some 3/8 holes through the rubber. It will take some rubber out and you can get the remaining chunk of rubber and steel sleeve out by hand. Should be able to destroy the tube and get it out. I suspect getting a new one in would be tricky.
Got the old ones out with the drill and beat method. Took a lot of time but made it out. Now putting the new ones in was just as bad. I got the passenger side in okay but the driver side will not go in all the way. I guess I will be looking to borrow or buy the tool. Thanks for the help
jpratt,
I will sell you the HRPartsNstuff Control Arm Bushing Tool (used for 2 removals and 1 insertion) and the HRPartsNstuff #0500 - GM Poly Rear Control Arm Bushings w/Grease fittings (2 for top Rearend, inserted in my Moser rear, removed without any use cuz I went with the Wolfe spherical UCAs) for a reasonable discount from the HRParts price, plus shipping from NorCal. I can't say what yet because their price list is down on their site right now and I can't remember what I paid. Send me a note at: jim_fisk@mindspring.com if you are interested - I can call them Mon to find out pricing then tell you.
Pix of both available if you want.
Regards,
Jim
See the Wolfe arms installed plus the rest of my G-body here:
http://home.mindspring.com/~jim_fisk/id1.html
