Turbo1dr
9 Sec Wanna-Be
- May 25, 2001
I think it's much easier to buy a car already restored than to go through all this trouble to do it yourself. The only good part about doing it yourself is you will KNOW what's under the paint and under the interior pieces.
Before...
During...
After: You'll have to wait and see!
Everything listed below is preventive maintenance...
Cleaned inside and outside of vehicle. Including the door jambs and under the package shelf just behind the rear window on the outside.
Thorough safety inspection before driving vehicle.
Reline front brakes with new seals and pads. Turned the rotors and repacked the wheel bearings.
Inspected, cleaned and adjusted the rear brakes.
Oil change, lubed chassis and checked all fluid levels.
Adjusted transmission shift cable.
Cleaned the rims
Cleaned engine compartment (still dirty)
Fixed the interior lights and under hood light.
Fixed hood latch so hood will release when inside cable is pulled.
Adjusted shift linkage after putting body bushings in
Adjusted steering gear
Front end alignment
Serviced Transmission
Serviced differential
Serviced powermaster (replaced fluid in entire brake system)
Everything listed below is NEW. These are things that are going to be installed or have already been installed: (*)=quantity
Factory Boost/Tachometer (recalibrated unit) (1): DONE
Shocks (4): DONE
Power door lock switches (2)
Power window switches (2)
Hood Shocks (2)
All body to frame bushings DONE
Upper ball joints (2): DONE
Lower ball joints (2): DONE
Upper control arm bushings on both sides (4): DONE
Tie rod ends, outer (2): DONE
Tie rod ends, inner (2): DONE
Drag link (1): DONE
Idler arm (1): DONE
Chrome OEM Headlight bezels (2)
Chrome OEM side marker lenses (2)
Window molding clips...front and rear
Seat upholstery...front and rear: DONE: (ready to be installed in car when ready)
Upper Door panels (2)
Simulated aluminum console over-lay: DONE: (ready to be installed in car when ready)
Simulated aluminum Dash over-lays: DONE: (ready to be installed in car when ready)
Simulated aluminum Glove box over-lays
Simulated aluminum door panel over-lays
Back-lit 145 Speedo over-lay. (recalibrated speedo..no reducers used)
Speaker panel for upper dash (1)
Diamond cut headlights with bulbs (4)
Interior panel clips for moldings and door panels
Cruise/Turn signal lever (1)
Shifter handle (1)
Trunk weather-strip (1)
Door weather-strip- upper and lower(both doors) (4)
Hood ornament...yep...I bought a NEW one! (1)
Carpet (1)
Power antenna mast repair kit (2) (one is for the GN too)
Door hinge pin/bushing rebuild kits (4): DONE: (ready to be installed in car when ready)
Window sweeps...inner and outer (both doors) (4)
Trunk lock chrome surround piece (1)
Headliner material (1)
Headlight adjusters (8)
Chrome Door lock pull handles (2)
A/C-Vent chrome surrounds (3)
Chrome door handles (2)
Chrome OEM door sill plates (the BODY BY FISHER pieces) (2)
Trunk Carpet (1)
Windshield washer jug (1)
Emergency brake pedal pad, brake pedal pad and gas pedal pad
Coolant overflow jug (1)
Rear Speaker carpet
Rear speaker adaptors for 6x9's
6x9 speakers
Front speakers
CD player
GM Ignition/Trunk keys
All reproduction decals (belt routing, jacking, caution fan, oil change recommendation sticker)
Everything listed below is MINT but "used":
Heater control cable: DONE
Lower door panels (2)
Sun visors (2)
Third brake light assembly (1)
A-pillar trim (2)
B-pillar trim (2)
C pillar trim...upper (2)
Arm rests (2)
Trunk lid (1)
Seat trim pieces for sides of seats (4): DONE: (already on seats and ready to be installed in car)
Dodge Intrepid dual cooling fans (1)
Things to fix after painting:
AIR CONDITIONING!!!
Things still needed as of May 25 2009:
DARK BLUE leather wrapped STEERING WHEEL
Reproduction SPID label under trunk lid
Reproduction weight/tire loading label in drivers door jamb.
Some pictures of the stuff...
Before...
During...
Cleaned the rims
Front end alignment
Shocks (4): DONE
Hood Shocks (2)
Drag link (1): DONE
Idler arm (1): DONE
Shifter handle (1)
Carpet (1)
Trunk Carpet (1)
Rear Speaker carpet
6x9 speakers
Front speakers
CD player
Sun visors (2)
A-pillar trim (2)
B-pillar trim (2)
Arm rests (2)
Trunk lid (1)
AIR CONDITIONING!!!
