UMI rear lower CA clunking..errrrr
Junior Samples
Walk Away
Just installed yesterday.
Holes drilled out 1/2 inch, no hobblen or hogging out the bolt holes on the frame so thats eliminated.
when I back out of driveway it will make a horrible clunk sound comming from what sounds like the front of the lower.. like something binding... going down the road is fine.. only slight left hand turn makes it groan.
I replaced one side at a time unbolting the sway bar.. should i unbolt the sway bar and retorque again together?
just trying to figure out what could be goin on.. all bolts are torqued
bars have less then 100 miles on em
Did you buy the tubular ones? I'm not a fan of the UMI lowers at all or the polly bushings they use. I had a set and couldnt get them to stop clunking. Also, use the blue marine grease on the outsides of them where they meet the frame. Thats helps some.
What type of sway bar? My ATR clunked a little bit.
