Greetings, brothers and sisters from the dark side. I was wandering if you guys could help me out with a couple of things. I had the mains on my block aligned bored and honed due to new center caps and main studs. I took the center to center measurement on the camshaft and crank (installed) with crank torqued to 90# to see if i needed an undersized timming chain. The measurement came out to 4.320". The factory spec is 4.335. I was expecting a difference of only a few thousands. The chains that are sold, at the most, are .006 under. Am I missing something? Can I get by using a standard T.C. kit?
My other question is. The cam button wore a depression inside the timming cover and I am going with a roller cam. Is there a fix for this so that I can use the roller cam button that requires shims? If I need to get a new one. What do you guys or gals recomend? Thanks for any input. May the BOOST be with you.
