Under the Coil?? Thats the Ignition Control Module?
hot air 84GN
Sorry for stupid questions, in advance. The part under the coil, is what I'm after. Im experiencing problems after the car is warmed up, cutting out and hesitation. Is there a way to test this part?
Looking for a good, operable, one of these parts. Let me know your $$
Is your ignition coil module an 84/85 or converted to 86/87? If yours is an 84/85 you will be forced to upgrade to the 86/87 by the economics. Brad
Same problem
Im having the same problem with my t type. Starting up weak, interment cutting out while idling, now its hesitating with a weak idle and backfiring. Could this be a bad ignition coil? I know its still the stock 84/85.
Caspers I think sells the conversion kit so you can upgrade to 86-87 model. If one is going bad, the car won' t idle, tends to stall and then won't restart easily.
ignition control module
I upgraded to Caspers 86/87 stuff. That's exactly what the car was running like. Ran strong when cold, then after restarting ran horrible. Stalling, backfiring and hard starting.
