Hey guys, when i first purchased my car, i found that it has a aluminum underdrive crank pulley, and all the other pulleys are stock. i have read that the pulley gives no gains in performance over stock. i would guess it gives about 5 hundreths of a second perhaps? sounds like a reasonable number. anyways, i notice that my alternator spins slow enough that the lights dim way down till you rev it to about 1K rpm. this tells me the alt and most likely the water pump are spinning too slow for my liking. my coolant temperatures are about 170 or so, with the high speed fan running, no AC on, and no radiator baffles or nothin. sometimes it will drop to 160 if im movin fast enough. NOW< what kind of a increase am i experiencing in coolant temperature, due to the slower spinning water pump? is there some way i can get a overdrve water pump pulley to spin the water pump at stock or faster speeds? if anyone has any numbers that they might have gotten from their use of the pulley, please let me know. thanks guys
