Scott89TTA
- Jul 12, 2005
I'm up and running now with all parts in sig now installed. I have the boost lines currently plumbed in the stock configuration. Think I have the TPS/IAC adjusted good now TPS .42 and IAC is ~ 16. With the ALKY knob set on 5-6 and the dump closed I'm around 20#'s boost no knock at all with the dump open I have seen ~25#'s boost and zero knock as well :biggrin: ...LED goes from red to green, O2's were ~780-810 but also as low as 760 (more so in the high 700's) and fuel pressure at WOT looked like it was about 60 psi and ~30 psi just cruising around ~38 psi at idle. Does this sound good or is it a little lean ?
Scott
Scott
