Updated Buick Gn Seperator Plate
chris718
Ck Performance Has Reproduced The Factory Buick Gn 2004r Seperator Plate. The New Plate Has Deleted The Third Accumulator And Third Clutch Checkball Feed Holes. The Plate Does Not Require The Use Of The Third Accumulator Or Third Clutch Checkballs To Be Installed In The Case. This Greatly Improves Third Gear Clutch Apply With Or Without Dual Feed Direct. The Second And Fourth Clutch Feed Holes Are Also Resized For Improved Performance. Plate Is Manufactured Using Edm Laser Technology And Is Hardened To Reduce Wear At The Checkball Seats. Price $24.99. Deleted Holes Are Shown In The Photo.
Recalibration Kit-w- NEW PLATE
Hi Chris.... is the new design on the seperator plate being offered in your RECALIBRATION KITS ????
How does this new plate compare to a TCI plate? TCI make an aluminum plate that leaves some holes out and you only need 4 check balls in the case. Just curious. @ least yours is steel and will stand up to the check balls better. Good price !!!!
Lee ive never seen a tci plate.ours looks just like a gm piece except for 2 deleted holes and resized clutch feed passages.
