Several guys have asked for the procedure.   So I will post it here.
Updating is done with the Key off, the TR6 does not even need to be installed.
Most of the units in the field are version 1.2 if they are over a year old, and 1.4 if newer. To check
the version turn on Mode 2 while the key is on, the error light will blink the version.
First, you will need a USB cable, and remove the round plug from the side of the TR6.
get the software from my dropbox link: open the zip file and drag the folder within it out to the desktop or some other location.
https://www.dropbox.com/s/p4z6e6l6kom85cs/TR6 Update Files.zip?dl=0
the zip file contains a folder with the updater program, some driver files, and 2 update files 1.4 and 1.5a
1.4 is the current shipping version, 1.5a has the low voltage error turned off once the
engine is running so the unit will work with the FAST ignition cut limiter box.
To put the unit in reflash mode, turn on Mode 2 then plug in the USB cable. Windows will likely want port drivers, direct its wizard to the CDC driver .INF file that is in with the update files.
Once the driver is installed, there will be a COM port created.
Run the win_hc08sprg.exe program, select the port, select the update file and hit connect. Once the program connects to the TR6, hit Autoprogram and the software will reflash the unit.
Hopefully this all makes sense, post questions and we can walk thru it.
Bob
Bob
