upgrade from art carr 9"
ryan319
my mods are in my sig. the art carr that i have is an older model that was recently refreshed and stalls around 3500. it's mostly a street car with a few quarter mile runs during the year. is there a converter that's worth upgrading too?
I find it hit and miss with the ART CARR convertors,you need to do a little math and see if its hurting you or not.
what MPH and RPM are you crossing the traps at?
what tire and rear gear ratio?
If you slip is high,than yes there is an upgrade
i've only made 2 decent passes with the car and both trapped at 106. i thought that was low but it was really hot out and i was only running a little over 16psi.
i have 28" radials and 3.42 gearing. i'm not 100% sure of my rpm though. it was less than 5400 because that's where my shift light is set and it wasn't going off.
