Hi all. I have a 1987(?) Buick "Regal" 231 in a Porsche 914. It is a street car only- not used for race or drag. Since it is a "classic" car and the area I live in, emissions are not a concern, and everything for that has been stripped off.
The rods are aftermarket billet I believe (info from previous owner). The heads have been gasket-match ported and have been modified to accept stud-mounted roller-rockers with slightly higher ratio than stock rockers. It has a "medium" lopey street cam in it (no idea of the specs?), and a 4brl Weiand single-plane manifold. The entire rotating assembly has been blue-printed and balanced. The exhaust is "Thrush"(?) long tube headers to 2.5" collectors going directly into 24" long turbo mufflers. A bit noisy!!
It had been running a Holley 390cfm 4brl carb and GM HEI distributor, BUT I am currently in the process of replacing the distributor and Holley carb with a 500cfm TBI + EDIS ignition system under Megasquirt-II control
With the carb it ran out of steam around 6000rpm-- due to either the 390cfm or possibly stock/weak valve springs. The valve springs will be addressed at some point.
From what I understand this setup (either Carb or TBI) should be around 200-220hp at the crank??
So... without going turbo or nitrous... What all else can I do to get more oomph?
I know the CR needs to be addressed. What are my best options for increasing the stock 8:1 CR? How far can be done safely on Premium pump gas? What kind of typical power gains can be had by increasing the CR? I should be able to pretty easily add a knock sensor with the Megasquirt system if necessary.
Thanks in advance!
Thanks in advance!
