My Block lean had been around 147 at idle and my TPS was .40 before changed the below.
Today we installed a new gas tank, Walpro 340 and hotwire kit.
Started the car up and the BL was the same and so was the TPS.
Adjusted the adjustable FPR and as we brought the pressure down from 47 to 40 (vacuum hose off) the BL went up to 150. We then raised the fuel pressure up and it lowered the BL to 144 thats the best we could get it. The TPS was set to .42
The car is bascially stock, just has 160 thermostat, boost set at 15 using the adjust actuator and a chip set for 18 degrees timing and 93 oct and the 160
I am also not getting any knock and the O2 reading at WOT in third is 880.
I thought that lowering the fp to 40 would have brought the BL down but the opposite happned, as I raised the FP up from 40 to 46 the BL went from 150 to 144.
I guess my question is what should I look for next.
