uppipe chips injectors ecm etc
badblknboostd
Pulling the hotair out. Lots of stuff for sale. Accufab fuel regulator 65$. Turbo tweak chip for hotair with 87 ecm stock turbo/injectors=== and the 1987 ecm 100$.1985 ecm wiring harness from left side of bulkhead to ecm 125$ Turbo tweak e85 chip for 60# never used and 7 used injectors( Delphi )i purchased that were supposed to be 60#100$.. G body parts 2.5 stainless hotair up pipe 100$. Complete UN damaged ac heat with evaporator heater core doors etc and um damaged mesh fresh air inlet from Cowl including blower motor and wiring 100$ a few more things.message me for what you need.located in middle TN.
do you still have the uppipe
Yes. Not on here much. Had a local guy wanting it all but he never came up with cash.
Is this a stock one I'm wanting to up grade
I don't know what you are trying to say. This is a 2.5 inch mandrel bent stainless pipe. The flex on it appears to be the same diameter internally.The stock one is covered in steel braid and 2" at best crinkled in the bends.
there is a down pipe about the same length that is flex also wondering if you had it alsos
Are those injectors 60's, flow-matched, and can I get a pic
No idea. I bought seven injectors from ls1 camaro guy. Was told they were 60s but numbers are scratched off. At the time the only thing that looked / measur d resistance like them were the seimens deka 60 and 80s. His car was tuned around 60s and ran good . he went to turbo and changed everything fuel related
