SignUp Now!Any idea how many miles are on the engine? How hard it was run previously?
Probably should consider a new timing chain, rings, bearings, complete valve job & seals, new valve springs, possibly new camshaft & lifters or roller cam, etc. Don't forget to insure that the oil pump & water pump are functioning correctly.
You just mentioned....a complete rebuild!Any idea how many miles are on the engine? How hard it was run previously?
You just mentioned....a complete rebuild!![]()
Okay I had a supposed fresh motor aswell With very low miles that I had just gone through . Put it this way I would go through any motor that is out with unknown health . If all is good then bolt it back together and be on your way but to not go through it while it's out is a gamble as you will see in this picture of a fresh build that was supposedly good to go by the seller I picked it up from . Luckily I saved the crank
If you did not hear it run, I would first do a leak down test.
