You are contradicting yourself.  When your stock wastegate solenoid was hooked up, working properly it is controlled electronically by the factory ecm, not very well either.  I know of a bunch of people with Innovative Turbo's MSBC working flawlessly.  Even know of one on a low 8 second, 1300 HP Buick that works without a problem.  It does have to be hooked up properly and you really need to understand how it works.  If you are using the stock wastegate actuator then there is alot of other things in the system that have to be working properly for it to control the boost.  As for the spooling question, your car will just have to be tuned properly for it to spool as well as it can.  There are alot of tuning tricks with the FAST that help spool up, you will have to find a good tuner.
