v-6 balanced rotating assembly
sscamino
balanced crank with weisco pistons,reconditioned stock rods with ARP bolts,flex plate . Everything has less than 800 miles ,the crank has some marks on it .Weber said might polish out at worst need cut.Everything is 10 under,also have 206 -206 comp cam roller cam out of same motor. Would like to get $1200 OBO for everything. Also have a set of stock heads with a valve job,new comp cams spings and new ARP bolts . email rbart1@verizon.net or call 724-775-3837 or 724-561-4470
bump
