Vacumm lines that need boost?
1QUICK85
Big Old Turbo Turd!!
I am lost..:( (go figure:))...............I got a vacumm line mess:D
I am running the V2 intake and have lines that need vacumm going to a closed vacumm block. So those are done!!
What I need to know is how to hook up the lines that need boost.........I have a port on the back of the intake, that is were the source for boost is coming from. I need to hook up the MAP sensor, the adj. fuel regulator, the wastegate rod(two lines), and the thing on the valve cover that helps control the boost? So were do I run the source line to.............just split it up and hook everything up or do I need to go to the thing on the valvecover first and then go to the rest of the stuff................
I need like a step by step if you can........:)
I know you guys dont all got a V2, but I need some help with this and I sure you experienced guys know this stuff!!
I am very close and hope to get her running this saturday........It has been a long process..........but thanks to this board and most importantly you guys it has been possible:cool:
A BIG TIA, Nick
Also what needs to connect to the vacumm port on the turbo............:confused: :confused: the fuel pressure regulator???????As you guys can tell I need your help bad.....:D
Nick
