Vacuum at idle
GBGN1
BP Performance Transmissions LLC
Still trying to chase down my engine wo's. ruff idle on new build . When cold and the TT chip has the blm locked it idles ok but closed loop idle is unstable . Checked compressin and all at 150-155. So that looks ok. Now I'm looking at checking vacuum . With my 218/212 comp roller with 1.65 rockers, what kind of vacuum would be optimal ? Could I get 15-16 out of it with big cam?
I only get about 13" at idle with my cam
What's the LSA on that cam? Those rockers don't help with the vacuum either.
112
What is the BLM at idle, and are you using the Extreme G chip?
You might need to use open loop idle, and richen it up a little.
Thanks Eric , I actually just last night Found that the machined intake is not sealing correctly and letting air in the ports I could actually spray carb spray down pushrods holes and engine idle would get better so in the process of fixing that. I installed ta .016 gaskets now going to use 1200's and machine intake again.One thing after another on this car....
