Hello all. I would like to like to know if there is a "better" arrangement of vacuum lines coming into the "vacuum block," and the vacuum block itself? As I was searching for a "boost leak" at fairly low pressure, 10 to 12 psi, I discovered air was coming out of everywhere! I also had a leak at T.B. to Plenum gasket, and IAC as well. I ordered a 4-piece gasket kit for everything in that area. However, I would really like to "redesign" the vacuum block/1 1/2" hoses that are to close together to secure them with "Ty-Wraps. Does anyone have any suggestions? thanks in advance.
