Vacuum Block on Top of Throttle Body
Hot Air
E85 and S.E./Carolinas Moderator
Staff member
I noticed that the rear port on my vacuum block is larger that all the other ports and that it is used for the PCV valve. I also noticed that it gets vacuum from a different port on the throttle body. Does anyone know why that is?
Conrad
Thanks. I was making it out to be much more technical than that...ported vacuum vs non-ported vacuum like on a carburetor.
Conrad
Conrad
It flows too much air and will weaken the vacuum signal on the other ports.
Thanks guys. I've learned a lot.
Conrad
