vacuum brake decision
I think you will find that the vacuum set up is much easier to work on and cheaper to fix if necessary. That Powermaster was always breaking down. I changed it twice before converting to vacuum.
Mine work ok and have never failed since the conversion, but are not what I would consider top notch. They at least work as well as the Powermaster set up. Others on forum have reported great success with the conversion.
Your wallet will like it.
I just reread your post. You have already made the decision and are wanting a place to do the job. Can't help you there, as I did the work myself. Others will chime in with their opinions.
Autozone?
Just look up the part numbers, and order them. I just got my parts this week, and it cost me $166 (still have to get the pedal), and when ordered online comes with a $15 gift card :D
converting to vacuum brakes wondering what company is recommended.thanks
You need to order a dual diaphram vacuum booster and master cylinder for a non-turbo 87 Regal. Actually, all G-bodies have the same set-up except some Montes use a single diaphram booster. Order a pedal from Gbodyparts.com
