There are threads on here about the hydroboost(the system on the 84 and early.85 turbo regals).
The vacuum set up requires changing the pedal to a vacuum pedal.
If you use the search function you will bring up lots of info on swaps. I'll see what I can dig up for links.
I do know in addition to a modified or swapped pedal you will need a booster and master cylinder. These can come from your local auto parts purveyor or else where. As above, just order parts for an 88 monte Carlo super sport. The pedal can be found at a recycler, one of the sellers here or by modifying your stock pedal.
Rich
Sent from my HTC PH39100 using TurboBuick Mobile mobile app
