Dec 9, 2016 #1 V VIN7 Member Joined May 24, 2001 Messages 595 Under boost is vacuum the same along the entire intake tube length? For example, if I were to place the port closest to the turbo inlet would the vac signal be higher than the other end closest to the maf? Thanks
Dec 9, 2016 #2 BEATAV8 The Engine Whisperer TurboBuick.Com Supporter! Joined Feb 14, 2002 Messages 5,844 yes, highest vacuum should be closest to the compressor. a pressure differential is what causes flow.
