Vacuum Manifold Mounting Locations
mtocrs1
Mtocrs1
Where are you guys mounting your vacuum manifolds if you are using one?
Let's see some ideas.
Firewall to the right of the coil pack
Sorry for the confusion guys, I already have the intake manifold tapped for a few ports but I am thinking about installing a remote vacuum Manifold. Looking on mounting ideas for the Manifold itself.
What are you going to be runing off that manifold ? If you where going to be runing your map off it . I would personally want it as close to the sorce as possible . As far as mounting it put it where ever is the most convenient for you to access . I'm a actully going to be pluming a Intake Manifold with individual throttle body's so I will need a vacuum block to get a map reading . I found this pretty cool setup
I put one in the how-to section but I didn't use a remote block.
The only think I would have done differently was to use straight 3/8" fittings instead of the 90's. I didn't have a complete car to look at when I did it, so I had to guess which one would work better.
I made a bracket out of some scrap steel and attached it to the passenger side of the plenum.
